1997 f250 front brakes dragging
1997 FORD F-250
AWC123
I have a 1997 f250hd with 205000 miles on it, i replaced the front brakes, rotors, and calipers about 6,000 miles ago, now they are starting to drag evenly on both sides, i cleaned the calipers and they seem to be fine. Any suggestions? Would the master cylinder make this happen if it was going bad? Thanks.
Oct 28, 2007 at 9:45 AM
Check the brake hoses could be acting like a one way check valve preventing the fluid to return back to the master cyl. or the master itself.
Oct 28, 2007 at 10:17 AM
