1996 Ford F250 Diesel - Water in fuel indicator
188,000 MILES • V8 • 4WD • AUTOMATIC
MASONOVICH
This warning light flickers on and off, and has done through at least two tanks of fuel on each of the two tanks.... Power doesn't seem to be affected, but I'd like to get it fixed. Advice?
Mason
Jun 24, 2009 at 1:56 PM
DZLDOC
  • 5 POSTS
if your fuel filter is a canister usually will have 2 but sometimes just 1 filter. there will be a drain on the bottom of the filter. turn counterclockwise and drain until straight fuel comes out. if you have an element filter that sits in the middle of your intake manifold up top there will be a drain petcock turn 1/4 turn wait for strong fuel odor and close.
Jun 26, 2009 at 6:28 AM
