1996 Ford F250 a/c , heat not coming out of front vents
1996 FORD F-250
202,000 MILES • V8 • 2WD • AUTOMATIC
STEVEO226
i tuned up my motor and as i was finishing, i snapped off a coffee straw sized red tube , about 6 inches in length, i believe was some vacuum line, i dont know. first ford i've ever owned, ever since then, heat or a/c does not come out the front vents, no matter what setting the climate control is set on. heat or a/c only comes out defrost area. what did i do? i tried to rig up another straw/tube with no results. did this little red tube attach somewhere else, why is it affecting my air vents flow? please help, summers coming and i tried the a/c but with it only coming out of defrost area, it does not work well . thanks
Apr 18, 2008 at 10:31 AM
BLACKOP555
  • 10,386 POSTS
can you get a picture of said straw sized hose and of the location.
did you replace the whole assembly for the hose or did you cut and splice a new one in it?
Apr 18, 2008 at 11:59 AM
