1996 Ford F-250
APPYZRULE
Transmission problem
1996 Ford F-250 V8 Four Wheel Drive Manual
I have a 1996 f250 7.3 powerstroke. just within the past couple days i have had a few problems. first the 4th gear went out, i can still get it in that gear but it grinds really bad. someone told me it could be a clutch plate, but not sure. second issue i've been having is it will start making a wierd noise and lose power but then gain power right after. and now the front end is starting to shake as well.
Oct 23, 2010 at 3:17 PM
TECH1FORD
  • 102 POSTS
the grinding just going into fourth is most likely the syncronizer in the trans, what type of noise is it making when it loses power, could it be the clutch slipping. Where is the noise coming from.
Oct 25, 2010 at 11:51 AM
