1995 Ford F-250 Just dies without warning
PITMANCC
  • 1995 FORD F-250
  • V8
  • 4WD
  • 169,000 MILES
My truck will start just fine for about a dozen tries. Then without warning it will just crank and crank. I wait a little while or try several times more and it fires right up and doesn't skip a beat. Lately it has started to die while I'm driving. I pull to the side and it usually fires right up again and runs perfect. Help!
Friday, April 25th, 2008 AT 5:07 PM
BLACKOP555
  • 10,371 POSTS
Best thing to do is wait for it to not start and check for spark at all cylinders with a spark plug tester then check the fuel pressure.
There are a bit of things that can cause a problem like this, and some are fuel related, some ignition so the best thing to do is wait and check as I suggested.
Friday, April 25th, 2008 AT 5:37 PM
LITTLESTEVE
  • 5 POSTS
It sounds like a fuel pump problem. If it happens again try beating on the fuel tank with your fist and see if it will start. If it does than thats your problem.
Monday, August 18th, 2008 AT 6:35 PM
