1995 Ford F250 ignition replacement
10,200 MILES • V8 • 4WD • AUTOMATIC
RICKEY
The ignition swich needs replacement. How do I remove this ?
Thanks,
Rickey
Feb 23, 2008 at 11:24 AM
2CARPRO JACK
  • 11,533 POSTS
There is a hole in the lower cover on the column that will allow access to the push pin that holds the tumbler in.If necesary remove just the bottom cover to gain easier access. Put key in and turn to on, press button and pull tumbler out, push new one in and you are done
Feb 23, 2008 at 11:28 PM
