1995 Ford F250 idle problems
BRGW
Engine Performance problem
1995 Ford F250 V8 Two Wheel Drive Automatic
I am having idle problems. The truck starts up fine but almost immediately after start up it dies if i dont step on gas pedal. The other day i had my brother start thr truck up while i took the vaccum hose to the egr valve off. after doing this the truck ran fine. then i coonected the hose back to the egr valve and the truck died. i have already replaced the egr valve and done a major tune up. what could the problem be.
May 15, 2009 at 9:49 AM
  • 75,988 POSTS
Clean out the idle air control valve and see what happens and also test the TPS sensor
May 15, 2009 at 9:55 AM
