what woul the truck do if it had a bad fuel pump would it try to start and die?
Sep 2, 2010 at 4:16 PM
MADMIKE1735
✓Experienced Mechanic
if it starts, then dies, sounds like fuel pump is no good.... remove fuel filter, turn key on, if fuel pumps out alot, then your problem is the fuel filter.... if not, replace the pump
