1994 Ford F250 Runs Rich
1994 FORD F-250
MEHBOOB
Engine Mechanical problem
1994 Ford F250 V8 Two Wheel Drive Manual
My ford f250 with a 460 runs rich. I have replaced the o2 sensor TPS and map sensors. Cap rotor plugs and wires. It is blowing black smoke, a lot of it. Is there something I may be missing or something else I could try in order to fix this problem?
Jan 8, 2010 at 6:49 AM
Running on the rich side
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jan 8, 2010 at 6:57 AM
MEHBOOB
I have replaced the o2 sensor, IAC TPS and MAP sensors. I will replace the tep sensor and see how it goes
Jan 8, 2010 at 9:55 AM
Best check the fuel pressure before you do that
Jan 8, 2010 at 9:57 AM
MEHBOOB
could it be possible for all 8 injectors to be leaking? what are the odds of that? The reason for asking is because all 8 sparkplugs were black full of carbon
Jan 8, 2010 at 10:26 AM
Check the fuel pressure end of conversion and get back with me
Jan 8, 2010 at 10:28 AM
MEHBOOB
I have checked the fuel pressure and its good. I also replaced the fuel pressure regulator, and the coolent temp sensor. Still burning way to much gas.. Could it be possible that I have to reset the computer? if so how do I do that?
Jan 9, 2010 at 6:42 AM
Your injector/s could be leaking
Jan 9, 2010 at 8:22 AM
