FUNCTION SELECTOR VALVE
Place function selector knob in specified position. Using a vacuum gauge, check for presence or absence of vacuum and compare to VACUUM DISTRIBUTION table. If test results are not as specified, check for kinked or broken vacuum lines. If vacuum lines are okay, replace function selector valve. See Fig. 1 .
VACUUM DISTRIBUTION
Selector Knob..Outside/Rec.. Panel/Def..Floor/Def
Position.............Door...........Door..........Door
OFF...................V.................V..............V
FLOOR..............NV...............NV.............V
VENT................NV...............V.............NV
MIX...................NV..............NV............PV
DEF..................NV...............NV............NV
Vacuum (V), No Vacuum (NV), Partial Vacuum (PV).
Jan 6, 2020 at 4:58 AM
(Merged)
