If you havent already, check all fuses and relays and body ground wires. It sounds like it is probably a loose wire some where, either power or ground. Check all wires and fusible links coming of of the starter solenoid, Thats where the truck gets its power from for the fuse box and acceseries, good luck,
Votes and feedback are appreciated.
SPONSORED LINKS
Thursday, February 19th, 2009 AT 12:27 AM
