1993 Ford F250 Rear Brakes locked
98,000 MILES • V8 • 4WD • AUTOMATIC
CRAZYCRACKER
I can not seem to get the rear drum brakes off of my truck, they seem like they are stuck on.
Mar 15, 2008 at 5:05 PM
MERLIN2021
  • 17,250 POSTS
You need to back the starwheel adjuster off, there is an adjustment hole in the back side, it will require the use of a brake spoon and a thin awl or screwdrive, push the adjusting lever away from the starwheel and back the adjustment off until the drum can be removed.
Mar 16, 2008 at 12:58 AM
BLACKOP555
  • 10,386 POSTS
sometimes i have noticed that they have a tendency to rust and freeze on there, especially the heavy duty modles.
if after what merlin says doesnt work for some reason
then it is probably frozen on and you can heat it up with a torch and hit it firmly untill it breaks the rust free.
Mar 16, 2008 at 1:14 AM
