1992 Ford F250 starting
176,000 MILES • V8 • 4WD • MANUAL
CORTISTHETORTIS
truck wont start. push the clutch in hit the key not even a tick. changed the selinoid on firewall 2wks ago was having same problem. ended up pulling wire off starter cleaned up a bit & away it went. this time not so lucky. time for new starter or what can i test it somehow?
Aug 21, 2010 at 9:31 AM
  • 75,988 POSTS
Could be the starter, starter relay, clutch switch and ignition switch
Aug 21, 2010 at 10:42 AM
