1992 Ford F-250
CHERRY GARCIA
  • 1992 FORD F-250
  • V8
  • 180,000 MILES
I have replaced every sensor and the coil and pickup coil because the truck would not restart after it warmed up now I have found that there is fuel in the cylinders after you shut it off causing the spark plugs to foul. After it sits a while it will start again. Could there be a wiring short causing the injectors to open after the ignition is shut off letting fuel dump into the engine? All plugs are fouled not just one or two. Could it be a bad injector circuit in the computer. Ok now I have replaced the fuel regulator and the truck still runs badly. If you pull the fuel pump fuse out it runs fine until the fuel pressure drops but it might run 15 seconds before it dies. Once it warms up it will not restart but if you pull the fuel pump fuse it will start back up. Could a plugged fuel return line cause excess fuel to the injectors?
Tuesday, October 12th, 2010 AT 9:59 AM
WRENCHTECH
  • 20,761 POSTS
No, but you can have a defective injector just just doesn't close properly. Check your oil level and see if it is getting diluted with fuel.
Tuesday, October 12th, 2010 AT 10:04 AM
TECH1FORD
  • 102 POSTS
Yes the injector driver cicuit could be shorting and keeping them on. You will need to get a noid light and that plugs into the injector and see if it is powered after the truck is shut off.
Tuesday, October 12th, 2010 AT 11:26 PM
WRENCHTECH
  • 20,761 POSTS
No, the injector driver could NOT be staying on since the power supply is cut off with the key, regardless of what happens to the driver wire.
Wednesday, October 13th, 2010 AT 4:31 AM
