1992 Ford F-250
1992 FORD F-250
ROADDOG4994
Engine Performance problem
1992 Ford F-250 V8 Two Wheel Drive Manual
why does engine surges when in idle?
Sep 24, 2010 at 9:57 PM
Clean the idle air contdrol valve and EGR/PCV valves also clean the MAF sensor with an electronic cleaner CRC and test the throttle position sensor, check for vacuum leaks and also the fuel pressure
Sep 24, 2010 at 10:04 PM
