idles at 2200 rpm's?
105,000 MILES • V8 • 2WD • AUTOMATIC
NANCY CHRISTIAN
replaced the ECM, engine runs very good but idles high at 2200 rpms. This is the second ECM replacement. Transmissions shifts fine, everything else seems normal.
Dec 15, 2007 at 9:22 AM
DAVE1.1
you might want to check the I A C, idle air controll.
Jan 31, 2009 at 12:44 PM
  • 55,682 POSTS
I agree with DAVE1.1, it sounds like the IAC valve is stuck open and needs replacement, here is the location of the IAC and how to change it out. This guide should help as well.
https://www.2carpros.com/articles/engine-idles-too-high
Oct 29, 2024 at 9:27 AM
