1991 Ford F250 fuel presure
160,000 MILES • V8 • 2WD • AUTOMATIC
KYTNKATT
truck starts but stalls out after a few seconds. both tanks have gas, and fuel presure at fuel rail is at 45 psi. when key is in the run possision. but as soon as you turn the motor over it drops to below 10 psi. it also drops to zero when you turn the key back to the off possission. anotherwords , it isnt holding presure....?????
Oct 9, 2009 at 9:35 PM
  • 75,988 POSTS
Check if the injectors are leaking to include the fuel pressure regulator
Oct 9, 2009 at 11:42 PM
