1990 Ford F250 High Idle
JJJHAWK
Engine Performance problem
1990 Ford F250 V8 Four Wheel Drive Manual 200k miles
If I run the engine above 2000 RPM, it suddenly revs up to 3000 RPM and stays there. I have to engage the clutch to bring the idle back down to normal idle. Then it will stay there and idle fine until I want to drive and it starts all over again. I have stopped driving it due to safety concerns and not wanting to burn up my clutch trying to bring the idle down. Could this be caused by the IAC and can it be cleaned?
Jan 12, 2009 at 7:15 AM
JAMES W.
  • 2,394 POSTS
Yes, the IAC can be removed and cleaned with plain old carb cleaner. This is a common problem with Ford trucks.
Jan 12, 2009 at 9:32 AM
JJJHAWK
Thanks, James
I will recommend this website to my friends.
Jan 13, 2009 at 1:12 AM
JAMES W.
  • 2,394 POSTS
Glad to help. Let me know if that doesn't do it. Then we'll go to "plan B", whatever that is.
Jan 13, 2009 at 5:07 AM
