1989 Ford F250 roughidle and low speed
1989 FORD F-250
12,500 MILES • V8 • 4WD • AUTOMATIC
1989REDTRUCK
firing on all 8.is rough at idle as though a vacuum leak i unplgged large unused vacuum port up on manifold and truck runs perfect?even at speed?what is this telling meis wrong note also replaced idle sensor on man already
Aug 9, 2009 at 8:20 AM
DR LOOT
  • 2,311 POSTS
I would remove and clean the PVC or replacement it may be causing some kind of malfunction with the circulating system of the vacuum
Aug 9, 2009 at 12:09 PM
