1989 Ford F250 rough idle , hesitation
85,000 MILES • V8 • 2WD • AUTOMATIC
My truck will idle rough after it warms up. Also when driving it hesitates as if it was missing, especially at low speeds. Will idle rough when stopped in gear. I've had it tuned up ( plugs, wires,etc.) Will run fine for a while when cold. No problem starting. No problem at highway speeds. Was wondering about idle control valve?
Thanks........
Jul 27, 2008 at 4:10 AM
MERLIN2021
  • 17,250 POSTS
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody
Jul 27, 2008 at 4:13 AM
Thanks for the suggestion! I'll give it a try. Thanks again,344...............
Jul 27, 2008 at 11:26 AM
MERLIN2021
  • 17,250 POSTS
let me know...
Jul 28, 2008 at 6:08 AM
