1989 Ford F250 removing actuator rod
STORMHAWKMN
Steering problem
1989 Ford F250 V8 Four Wheel Drive Automatic
Can you tell me how to replace the actuator rod for the ignition on a 1989 ford f250 with tilt wheel?
Jan 6, 2009 at 7:37 AM
RACEFAN966
  • 5,029 POSTS
No the rod usually don't go bad it usually the steering key rack unit. These are not easy to replace I will not lie to you. You need to totally disassemble the steering column to do this. If you still want to do this your self let me know I will try to get you pics an such. It takes about 1.5 to 2 hours to do let me know what you want to do.
Jan 7, 2009 at 2:51 AM
STORMHAWKMN
Yes I would like to know what to do to replace it
Jan 7, 2009 at 4:31 AM
RACEFAN966
  • 5,029 POSTS
Do you have a repair manual? Can you get one from the library? You will need to take the steering wheel off and the turn signal switch will need to be moved out of the way and the shift collar will need to be removed and then you are into the heart of where you need to be. If you do not have or can't get a repair manual then I will get mine down and I will scan and e-mail the procedure to you. Let me know.
Jan 7, 2009 at 1:52 PM
