1989 Ford F250 Heater Core
1989 FORD F-250
94,000 MILES • V8 • 4WD • MANUAL
WILSONCOOPER@VERIZON.NET
How to I replace the heater core in my 1989 Ford F250 pickup V8 460 engine air conditioning 4 wheel drive
Jun 5, 2010 at 3:54 PM
  • CERTIFIED EXPERT
Fig. 20 Disassembled view of heater case
https://www.2carpros.com/forum/automotive_pictures/12900_hc_9.jpg
1.Allow engine to cool and release pressure from system, then disconnect heater hoses from heater core tubes, and plug hoses. 2.Working in passenger compartment, remove glove compartment assembly. 3.Remove seven screws attaching the heater core access cover to plenum chamber. 4.Disconnect vacuum lines, then remove the cover with the vacuum harness attached. 5.Remove heater core from vehicle, Fig. 20. 6.Reverse procedure to install. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jun 5, 2010 at 5:13 PM
