1989 Ford F-250 engine cranks but wont start
TONYJOHNSTON
  • 1989 FORD F-250
  • V8
  • 4WD
  • MANUAL
  • 180,000 MILES
I have changed out the coil, the pickup coil, the control module and the engine control relay
Monday, July 28th, 2008 AT 2:41 PM
DOCFIXIT
  • 18,828 POSTS
Need to narrow down the search. Pull plug wire place next to block crank good 1/4 in blue spark?
Spray some carb cleaner in throttle body what happened?
Post results
Monday, July 28th, 2008 AT 2:49 PM
KLSHIEL
  • 163 POSTS
Check that you are getting spark at the plugs. Then check your timing.
Sounds like you're missing spark-Do you have power to the coil?
Check the computer for code/s if any comeback with it this is where we start.
Monday, July 28th, 2008 AT 2:50 PM
