Engine Idle Is Erratic
147,000 MILES • V8 • 4WD • MANUAL
DAMIEN256
Hi guys, I have a 1989 5.8L and the idle is all over the place. I did a major tuneup, changed TPS, AIC and it still has the same problem. When at idle, (no load), the engine just will not idle at one speed. The RPMs are always moving up or down, 800 to 1300 to 900 to 1200 to 900 you get the idea. It will not stay at one RPM for more than a second or two. Can some one please steer me in the right direction?? PLEASE?? I am at a loss as to what it might be. Any help would be appreciated. I asked for help earlier and was recommended to change TPS and AIC which I did. Thanks for any help.
Jan 25, 2009 at 12:34 PM
  • 75,988 POSTS
When was the last tune-up?
Check engine compression, PCV and EGR valves, Vacuum leaks
This guide should help you
https://www.2carpros.com/articles/a-comprehensive-guide-to-diagnosing-and-fixing-erratic-engine-idle
Please go over this guide and get back to us.
Jan 26, 2009 at 2:24 AM
DAMIEN256
3 days ago I finished a major tuneup on it. There are vacuum hoses all over the place. Is there an easy way to check for vacuum leaks?
Jan 26, 2009 at 9:15 AM
  • 75,988 POSTS
Use WD40 and spray into the areas of the intake manifold/base of throttle body/vacuum hoses when the idle smooths out you've found the leak or use a stethoscope to track the leak by the hissing noises, or the propane and scantool method
Jan 27, 2009 at 5:00 AM
