Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Symptoms
Not Running
1989 Ford F250
1989 FORD F-250
10,000 MILES • V8 • 4WD • AUTOMATIC
MAUREENSGARDENS
MEMBER
1 POST
while i was driving truck died and will not restart
Mar 30, 2008 at 5:57 AM
BLACKOP555
Experienced Mechanic
are you getting bright blue spark
at
all
cylinders?
check each one, with a spark tester and make sure your using a good ground on it, if no spark check directly from coil.
you have gas in the tank im hoping? and you didn't run it out of fuel then re add fuel and it didn't start?
Mar 30, 2008 at 11:51 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
