1989 Ford F250
1989 FORD F-250
10,000 MILES • V8 • 4WD • AUTOMATIC
MAUREENSGARDENS
while i was driving truck died and will not restart
Mar 30, 2008 at 5:57 AM
BLACKOP555
  • 10,386 POSTS
are you getting bright blue spark
at
all
cylinders?
check each one, with a spark tester and make sure your using a good ground on it, if no spark check directly from coil.
you have gas in the tank im hoping? and you didn't run it out of fuel then re add fuel and it didn't start?
Mar 30, 2008 at 11:51 AM
