1989 Ford F-250
150,000 MILES • V8 • 4WD • AUTOMATIC
ARTISTIC
truck stoped on road. towed to shop.
checked for spark. no spark at coil.
Changed coil. still no spark.
checked coil on another identical truck. coil worked fine.
changed ignition module on colume. no spark.
suggestions?
Oct 28, 2010 at 3:21 AM
TECH1FORD
  • 102 POSTS
If you change the ignition on the steering colume like you said then you just replaced the ignition switch , the ignition module on that year of truck is on the distributor if not it is on the inner fender well on the driverside.
Nov 1, 2010 at 2:23 AM
