1989 F250
SQUIRRELGRAVY
MY FORD F250 WILL JUST DIE ON ME, SPUTTERS A LITTLE AND DIES.
AFTER IT SETS FOR SEVERAL HOURS IT WILL START AGAIN.
I HAVE REPLACED THE FUEL PUMP, HAD THE MODUAL CHECKED, THE TRUCK WILL RUN ON A GAS FILLED RAG IN THE AIR INTAKE UNTIL THE GAS IS GONE OUT OF THE RAG. I HAVE 40 LB OF GAS PRESSURE WITH ENGINE OFF I HAVE 32 LB WHEN ENGINE IS RUNNING.
Apr 28, 2007 at 7:08 AM
MERLIN2021
  • 17,250 POSTS
Check the pressure regulator on the fuel rail, And are any codes present?
Apr 28, 2007 at 2:05 PM
SQUIRRELGRAVY
45# at the pressure regulator & no codes
Apr 30, 2007 at 8:39 AM
