1988 Ford F250 oil pan replacement
BTSUNPOWER
Engine Mechanical problem
1988 Ford F250 V8 Four Wheel Drive Automatic
Does the engine have to be pulled in order to replace a very rusty oil pan?
Jun 16, 2010 at 4:58 AM
BLACKOP555
  • 10,386 POSTS
nope! remove cooling fan and shroud. from there loosen engine mounts and put a cherry picker on engine and secure it. then remove mounts and lift up engine enough to pull out pan.
Jun 16, 2010 at 3:20 PM
