HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Ignition
No Spark
1988 Ford F-250 No spark
VALDARLING
MEMBER
1988 FORD F-250
6 CYL
2WD
MANUAL
125,500 MILES
Replaced most of the ignition parts could the engine control module be problem?
Friday, September 10th, 2010 AT 8:57 PM
MECHANIC
If you check and test the coil, cap/rotor, distributor pick-up coil, ignition control module the only one left is the brain box
Friday, September 10th, 2010 AT 9:03 PM
VALDARLING
MEMBER
1 POST
Ordered one today.
Saturday, September 11th, 2010 AT 9:43 PM
Please
login
or
register
to post a reply.
Related No Spark Content
Still No Spark
I Have A2001 Ford F250 5.4l We Changed The Engine Ive Checked The Wiring Harness Numerous Times Changed The Coil Packs And Plugs But Still...
Asked by
erintaylor5
2001
FORD F-250
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
No Spark
96 Ford F250 7.5 No Spark From Wires New Rotor And Cap Still No Fix Has Duel Tanks Switch Tanks Nothing New Ignition Coil Main Distributor...
Asked by
hutch3902
1 IMAGE
1996
FORD F-250
2002 Ford F-250 Ignition Failure
It Is Hard To Crank In The Mornings You Have To Plug It Up. If It's Been Plugged Up Will Run Good. I've Replaced All The Glow Plugs And I...
Asked by
gerber78
1 ANSWER
2002
FORD F-250
1992 Ford F250 Firing Order
My Truck Has Been Fouling Its Plugs And So I Checked The Firing Order And It Was Wrong So I Corrected It Now It Wont Start And It Back Fires...
Asked by
jrmotors
1 ANSWER
1992
FORD F-250
Information On Glow Plugs
Need To Know The Location Of The Glow Plugs On A Ford 6.0
Asked by
Bodkins
1 ANSWER
2004
FORD F-250
VIEW MORE
Ignition No Spark
Ignition System Testing
Ignition Coil System Test Repair - All Cars
