1988 Ford F250 loose of pip siqnal after running for about
1988 FORD F-250
126,000 MILES • V8 • 4WD • AUTOMATIC
DB4U2PLAY
I have replaced all of the coponets that deal with this i put in new dist. with pick up, new module, new map, new eca, and after all that it still doing the same thing but seem to be getting worse i checked grounds at eca they all are good new ignition switch but the pip signal still is lost
Oct 16, 2009 at 2:37 AM
MERLIN2021
  • 17,250 POSTS
Check the eec relay. This relay is mounted under the dash next to the ecm (on bronco), not sure if in the same spot on the f-150's. This relay is also powered from a fusible link. The eec relay, and fusible link can go bad after time and cause a crank no start condition with no power to the fuel pumps, injectors, ign. module etc. See if there is any corrosion in the socket.
ON A 4.9L. IN THE WIRING HARNESS THERE IS TWO WIRES (WHITE WITH A BLUE TRACER) JUST ABOVE THE OIL PRESSURE SENDER THAT TURNED GREEN AND BROKE. THIS IS THE WIRE THAT POWERS UP THE COIL FROM THE IGNITION SWITCH.
Oct 16, 2009 at 8:27 AM
