HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1988 Ford F-250 FEUL PUMPS
CLASIERAY
MEMBER
1988 FORD F-250
Other Category problem
1988 Ford F250 Engine Size unknown Four Wheel Drive Manual 160000 miles
I JUST CHANGED OUT MY FEUL PUMP AND NOW IT WONT START WHAT DID I DO WRONG?
Wednesday, December 12th, 2007 AT 8:02 PM
BLACKOP555
MECHANIC
Are you getting 12v to the pump? If so make sure the connections are tight by pushing on it while having someone turning hte key to on and off.
Post back yoru results if you have 12v or not.
SPONSORED LINKS
Wednesday, December 12th, 2007 AT 8:17 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
2002 Ford F250 Changing Fuel Pump
Engine Mechanical Problem 2002 Ford F250 V8 Four Wheel Drive How Do You Change The Fuel Pump? Do You Have To Have Any "special" Tools...
Asked by
BrittneyM
1 ANSWER
2002
FORD F-250
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
No Fuel
I Have A 2002 Ford F250 With A 5.4 That Will Not Pump Fuel. I Changed The Fuel Pump Twice Thinking The First One I Bought Was Defective....
Asked by
cherzog
1 IMAGE
2002
FORD F-250
Fuel System
I Have Changed The Fuel Pump And The Filters And The Fuel Exchange Valve. The Gas Goes Into The Carb And The Truck Will Start. But When The...
Asked by
j lannon
1 IMAGE
1987
FORD F-250
Accelleration Problems
1985 Ford F-250 Pick-up, 302 Cu. In. With 5,000 Miles On New Engine. Weak Acceleration, Sluggish, Very Little Power, And Sometimes Back...
Asked by
JoeGuzzardi
FORD F-250
1989 F250
My Ford F250 Will Just Die On Me, Sputters A Little And Dies. After It Sets For Several Hours It Will Start Again. I Have Replaced...
Asked by
SQUIRRELGRAVY
1989
FORD F-250
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Fuel Pump Pressure Test
Engine Not Starting
Online car repair manuals
