1988 Ford F250 acts like out of gas
86,000 MILES • 6 CYL • 4WD • MANUAL
LEWIS M
runs fine sometimes but others it seems starved for gas. has new tank,both pumps are new and filter. running codes show lean condition and coolantand air temp sensors out of range. both ohmed ok and 4.7 volts at plug.
Jan 27, 2008 at 1:03 AM
MIKE H R
  • 3,094 POSTS
try cleaning out the throttle body with cleaner with out it running. then start and let the truck run a couple of minutes after you clean any carbon that has built up. The truck will run rough at first until the cleaner has burnt up.
Jan 27, 2008 at 2:33 AM
