1987 Ford F250 How to replace ignition switch on 1987 F250
1987 FORD F-250
11,200 MILES • V8 • 2WD • AUTOMATIC
4BEATGAIT
How can I replace the ignition switch on my 1987 F250 auto transmission? (Also, since the ignition swith broke I cannot shift out of park.)
Jul 28, 2008 at 6:52 AM
SHOOTERS
if you look under the ignition area you will see a small hole straighten a paper clip and push it into the hole , there is a release pin inside the hole
Sep 26, 2008 at 1:25 AM
