1987 Ford F250 Cluch Pedal Going to the floor
1987 FORD F-250
JULTYMACK
Transmission problem
1987 Ford F250 V8 Four Wheel Drive Manual
I would like to know what is the problem if my cluch pedal goes to the floor and stay at the floor what is the problem?
Dec 25, 2009 at 11:58 AM
Check the clutch fluid level if okay -check for external leaks if none check the clutch master cylinder could be leaking internally and clutch slave/servo.
Dec 25, 2009 at 6:00 PM
