1987 Ford F-250
LAWNGUY
  • 1987 FORD F-250
Electrical problem
1987 Ford F250 V8 Two Wheel Drive Automatic
how do I remove the key ignition from the collum without a key?
Monday, January 19th, 2009 AT 9:11 PM
KEVIN12881
  • 336 POSTS
You will need a steering whell pully. Aso get a haynes book if you can afford it. Take off the steering wheel cove, two screws in back. Once you see the larg nut, look for to line to show its position. You can make one with a marker. Then remove the nut. Sterring wheel will come off. You will have several lock washers that will need to be removed with specil needle nose pliers. It is pretty straight forward, I suggest the haynes book. You will eventually get to the ignition and have to remove one screw. Can be different on your car
Monday, January 19th, 2009 AT 9:23 PM
KEVIN12881
  • 336 POSTS
You should not have air bags, but if you do REMOVE THE FUSE FIRST
