1986 Ford F250 Truck won't startup
1986 FORD F-250
87,000 MILES • V8 • 2WD • MANUAL
ANGELITOS
My 86 Ford Lariat will not startup (no cranking), also the dash lights do not lightup. I ve replaced the batterry, battery cables, the Relay, Ignition starter switch, and clutch/starter interlock switch. When I attempt to startup, nothing happens.
Apr 26, 2010 at 5:21 PM
Check and test all the fusible links and ignition switch
Apr 26, 2010 at 10:37 PM
