HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-250
Drivetrain
Transfer Case
SPONSORED LINKS
1986 Ford F-250 Fireing wrong
FALLON84
MEMBER
1986 FORD F-250
Engine Mechanical problem
1986 Ford F250 V8 Four Wheel Drive Automatic
My 86 f250 is fireing wrong on one of it's cylenders I don't know what has caused this or where to start to look
Sunday, January 17th, 2010 AT 12:52 PM
MECHANIC
If its firing wrong sound like you're talking misfiring-check the sparkplug/ comression /injector
SPONSORED LINKS
Sunday, January 17th, 2010 AT 1:18 PM
FALLON84
MEMBER
Just put brand new glow plugs in so check comprestion and injectors ok
Sunday, January 17th, 2010 AT 2:25 PM
MECHANIC
Didn't know it was heat of compression engine/Diesel-could be coming from the injection pump
Sunday, January 17th, 2010 AT 2:36 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
4 Wheel Drive Hub Lock Manually
I Have 2000 Ford F250 I Can Not Get My Hub To Manually Turn On Passenger Side Of Truck
Asked by
ruckerbetty
2000
FORD F-250
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
F-250 4x4
4 Wheel Drive Slipps Out When Stopping.
Asked by
BigT
2006
FORD F-250
1999 Ford Ranger Four Wheel Drive
I Own A 1999 Ford Ranger 4 X 4, Automatic, 250,000 Km. Does Anyone Know How To Convert From Vaccuum Assist Four Wheel Drive To Manual...
Asked by
Harmony
1999
FORD F-250
Transfer Case On 1991 F250 Powerstroke
I Am About To Buy A 91 F250 Powerstroke. The Guy I Am Buying It From Said The Transfer Cae Needs Overhauled. Is It Cheaper To Rebuild It Or...
Asked by
psj011777
1991
FORD F-250
1999, F-250, 5.4 4x4
The Heat Is The Only Thing Comming Out Of The Vents. I Did Bypass The Hoses And The Air Works Fine. With Them Connected The Heat Is All That...
Asked by
rodvent
1 ANSWER
1999
FORD F-250
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Automatic Transmission Service
Wheel Bearing Hub Replacement
Online car repair manuals
