Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Electrical
Ignition Switch
Replace/Remove
1984 Ford F250 ignition cylinder
1984 FORD F-250
100,000 MILES • V8 • 4WD • MANUAL
WHITEHEATHER
MEMBER
1 POST
how do i remove the ignition cylinder to replace with new one
Dec 9, 2007 at 4:55 PM
MERLIN2021
Experienced Mechanic
Disconnect the neg batt cable, remove the steering wheel, place cylinder in run position, use a 1/8th drill bit and push the pin as in the diagram...
Dec 9, 2007 at 6:46 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
