1984 Ford F250 Engine conversion
165,000 MILES • V8 • 4WD • MANUAL
RODBENDER
I would like to convert my 6.9 diesel to gas. I have found a rebuilt 1983 390cu in and would like to know:
1. Will the bell housing from the diesel bolt up and match to the 390
2. Will I need to buy a conversion kit for motor mounts
3. What other conversion issues should I consider before purchasing the 390
Aug 25, 2009 at 3:37 AM
MERLIN2021
  • 17,250 POSTS
With 165,000 you should put new mounts in! Should bolt right up. Will need ignition moude.
Aug 25, 2009 at 3:49 AM
