1979 Ford F-250 ENGINE DYING
DWYATT3314
  • 1979 FORD F-250
  • V8
  • 150,000 MILES
MY PICKUP WILL START WHEN COLD, BUT ONCE IT RUNS A WHILE IT WILL DIE, WILL CRANK BUT ACTS LIKE TI IS GETTING NO FIRE
Thursday, April 9th, 2009 AT 10:35 PM
Next time it does it-do below immediately to determine if its fuel or spark issue
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, April 9th, 2009 AT 11:53 PM
