1978 Ford F250 multiple battery failures
1978 FORD F-250
150,000 MILES • V8 • 2WD • AUTOMATIC
BRITISHSAFFORD
i have a 1978 Ford F-250. Last october i replaced the almost new (18 month) battery, as the first had gone bad. Now, 4 months later the battery charger is telling me that this 3rd battery has 'gone bad'.
The truck sits quite a bit as i use it on and off around the farm. Any thoughts as to why i am going through batteries so fast? Also, is there any thing that i can do with these old batteries that i am collecting or are they done?
Mar 8, 2009 at 6:26 AM
  • 110,244 POSTS
HI:
Have you had the alt and voltage regulator checked? It could be over or under charging causing the battery to go bad.
Also, most parts stores will take the old batteries.
joe
Mar 8, 2009 at 7:07 AM
BRITISHSAFFORD
thank you Joe, i'll check it.
Bob
Mar 8, 2009 at 11:10 AM
  • 110,244 POSTS
Bob,
Let me know what you find. Something tells me there is a problem with the regulator.
Mar 9, 2009 at 3:44 AM
