1963 Ford F250
67,000 MILES • V8 • 2WD • MANUAL
MAHERSAUTO
i have a 1963 ford f250 when i turn the key the starter just spins it does not inject to turn the engine over and i changed the battery cleaned every ground and all connections new cellinoid and it still just spins i took the starter off hooked it up to a jump box and it works it spins but does not push out before i buy a whole new starter and wast my money does any one have another answer.
thanks nick
Aug 1, 2010 at 9:04 AM
EDWARD.S
  • 166 POSTS
Hi,From What You Are saying ,Sounds like The Starter Drive Is Bad. When You Take The Starter out,Look At the Flywheel For missing Teeth Also.
Hope This Helps You,
Good Luck
Edward S.
Aug 1, 2010 at 9:14 AM
