1974 Ford F250 charging system
100,000 MILES • V8 • 2WD • AUTOMATIC
JAYSONDC
put new alternator on and voltage regulator and truck still wont charge had alternator tested and battery could something be wrong still with the voltage regulator or is there a wire broke somewhere
May 21, 2010 at 12:39 PM
MERLIN2021
  • 17,250 POSTS
Check the battery cables and the fusible links, these are the three wires that attach at the starter solenoid, follow the positive cable from the battery, takes you right to it. Any repairs, remove the negative cable first, and put back on last.
May 21, 2010 at 12:44 PM
