1973 Ford F-250 timing
JROD13
  • 1973 FORD F-250
Engine Mechanical problem
1973 Ford F250 V8 Four Wheel Drive Manual
my truck is overloding with fuel and then cuting out when I git on the throtle depending on which way turn my distributer cap if I set the timing with a timing gun will it fix my proble
Monday, March 16th, 2009 AT 11:51 AM
BLACKOP555
  • 10,371 POSTS
Check the ignition timing. Only thing is vehicle has to be warm, running at proper idle speed in order for you to set the timing properly.
Does it run good when cold? Or bad all the time?
Monday, March 16th, 2009 AT 2:31 PM
