won't start with key & key won't return when released
FRWLT3
I have a1999 F150, 5.0, automatic,with power stearing & power brakes. When I turn the to start it, nothing happens and when I release the key,it just stays there and I have to turn it back to the run position. I have to start it from the relay under the hood. How can I correct this problem.
Nov 26, 2007 at 11:20 AM
FISHERMAN
  • 937 POSTS
[quote:40225341de="frwlt3"]I have a1999 F150, 5.0 Auto,with power stearing & power brakes. When I turn the to start it, nothing happens and when I release the key,it just stays there and I have to turn it back to the run position. I have to start it from the relay under the hood. How can I correct this problem.[/quote:40225341de]
Hello !!
looks to me like you have a faulty ignition switch...
(could be a bad or broken contact inside)
check it and replace it if necessary.
good luck!
Nov 26, 2007 at 11:24 AM
