warning beeper that never stops, even when key OFF and out.
MHERNAN
I am repairing a Ford F150, 06/98, 4X4 that was hit by a tree dead center pushing the core support back and damaging the fan only a little. We stripped all the sheet metal to try to start it (which it won't...but that's for another day). Our problem is a beeper that goes off every few seconds with the doors closed and the key out until it kills the battery. The sound comes from the passenger kick panel near the fuel pump reset switch (which we reset after the crash...but the pump still doen't run). This is my first trip to your site...I hope you can help. Mike in Ohio
Mar 3, 2007 at 2:23 AM
BHUGG
  • 157 POSTS
As for the fuel pump, did you check the fuses in the power distribution box under the hood. There is also a fuel pump relay in the PDB that might be bad.
The beeping might be from a damaged door switch. Does the dome light stay on? If so, change the door switch.
If we help, let us know.
The forum is here to help and we want to know if we are helping.
Give us a vote if we deserve it.
Mar 3, 2007 at 5:28 PM
