[quote:632baee499="blackop555"]try priming the engine a bit before starting it. turn the key to the on position then hold there for 5 secs then turn off repeat this 3-5 times.
then crank the engine, if it starts right up check the fuel pressure regulator or fuel pressure check valve.[/quote:632baee499]
The regulator has no bolts holding it on. Does it have a spring like the hoses or does it come off some other way?
Nov 10, 2007 at 7:17 AM
