Unstable Oil Pressure
TEXASRED85
  • FORD F-150
I have a 1997 Ford F-150 V6 186K miles. The oil pressure has become very unstable. When I am not on the throttle, the oil pressure drops dangerously low. As soon as I am back on the gas, oil pressure is back to normal. Or I can put it in neutral and the pressure is back up. The oil pump is less than a year old. Whats the problem?
Monday, August 20th, 2007 AT 1:41 PM
TEXASRED85
  • 5 POSTS
Lower intake gasket failed and let water into cylinder 5. Did a full rebuild and replaced the oil pump while I had the motor out.
Monday, August 20th, 2007 AT 2:23 PM
TEXASRED85
  • 5 POSTS
I could not find a mechanical oil pressure gauge to use. I went ahead and picked up the sending unit since it was only $10. Where is is located?
Monday, August 20th, 2007 AT 4:53 PM
TEXASRED85
  • 5 POSTS
Nevermind I just found it
Monday, August 20th, 2007 AT 5:04 PM
