1988 F150 supercab 4x4--351 engine 162030kmh. went to work this morning truck started and ran great. Went to go home for dinner and it would not start. It would crank over but it would not even fire, I kept trying for 10 minutes even pushed the gas pedal to the floor and tried thinking I had flooded it but still nothing. Came back after work and it still wouldn't start. Caught a ride home and came back after supper and tried it but still nothing. Held gas pedal to floor and cranked and cranked finally started ran great. Drove it home shut it off and tried to start it and all it would do is turn over, wouldn't fire at all. Changed the TFI IV module but didnt make any difference. Came home from work next day tried truck took a bit had to step on gas pedal truck started, shut it off and started it a few times checked the timing it was good shut it off and then went to start it again and it would not start, would not even fire. Can hear a loud hum when key is turned on and a click, checked pressure on fuel rail pressure reads 40 pounds when key is turned on. Hope you can help THANKYOU. Desperately needin help
Jan 18, 2007 at 10:15 AM
